1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
EJ1 D16Z6 RPM guage problem
Old Jul 12, 2015
brennov8's Avatar
brennov8 is an unknown quantity at this point
Hi dudes, i'm from brazil and i have a 94 civic ej1 exs mt d16z6.
My car are have a rpm guage problem, at idle the guage shows 700-800rpm, at 60mph show 2000rpm and the cut-off are on 5900-6000 when its suppose to be 7200 rpm
what can be the problem?
ps: sorry my poor english
Old Jul 12, 2015
Re: EJ1 D16Z6 RPM guage problem
Is that the original and correct engine for that year and model of car?
Is the computer correct for the engine you have?
Did someone replace the engine but not replace the computer with one specifically for the new engine?
Old Jul 12, 2015
brennov8's Avatar
It's all OEM
The car are the same as brand new, same engine, same ECU nothing has been changed.
Old Jul 12, 2015
Have these readings changed since the car was new?
If the tachometer has become inaccurate, readings may appear lower than actual?
Old Jul 12, 2015
brennov8's Avatar
Exactly the readings may appear lower than actual.
I bought the car from a friend of mine and he told me that some time ago the rpm began to show a lower value than the actual.
Old Jul 12, 2015
brennov8's Avatar
thats my car in the video the first gear cuts at 6000 rpm and 35 mph
Old Jul 12, 2015
If you want to confirm the tachometer on the dash is not accurate, obtain a different "known good" tachometer (digital, aftermarket gauge, or voltmeter-multimeter with tach function), connect it to the RPM test connector then compare?
Old Jul 12, 2015
brennov8's Avatar
They engine are running 7200rpm but the tacho shows only 6000. whey i'm driving the rpm increase normal at idle to 2000 rpm after this increases slowly
Old Jul 12, 2015
The tach gauge in the dash is probably bad, but using another as a test would confirm the inaccuracy.
Old Jul 13, 2015
brennov8's Avatar
Today I dismounted my cluster and clean it, remount and start the car now its cutting on 6150-6200 rpm, i dont have money to try other guage. Any other optiom?
Old Jul 13, 2015
Small improvement? Clean it some more?
Save money to
-buy a new gauge
-buy a good used gauge from a auto recycle yard
or ignore the bad gauge, it is not hurting performance nor hurting the rest of the car
Wild Cranker
May 19, 2015 06:10 PM
tylerginevan
Apr 27, 2015 12:29 PM
McD
Apr 16, 2015 10:46 AM
dooner24
Apr 14, 2015 07:51 PM
Aznnp77
Nov 8, 2001 04:49 PM
