Removing air cleaning box above throttlebody-No Bolts, just a round Clamp
Old Jun 26, 2015
wasa67's Avatar
wasa67 is an unknown quantity at this point
Hello
I know this has been posted a ocuple of times, but I am having trouble finding the right manual or instructions. I need to clean the throttlebody and IAC, but to get to those I first need to remove the air cleaning box sitting on the throttlebody. However, after removing the clamp to remove the top of the box, remoing the air intake hose, and removing the filter, I noticed that the Bottom of the box is connected to the throttlebody with a metal round clamp, which I cant seem to remove. Click image for larger version
Anyone help please?
Old Jun 26, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: Removing air cleaning box above throttlebody-No Bolts, just a round Clamp
It must have spun around so you do not see the probably 10mm socket head bolt. it's like a hose clamp. Fill under and around it and find the head. Then use a screwdriver socket driver on it.
Old Jun 27, 2015
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
You can see the screw adjuster on the left side of the pic. You will have to reach it from the back of the TB.
Old Jun 27, 2015
wasa67's Avatar
That's actually a bolt from another component, its appearing as the adjuster from the ring. But I will attempt to turn the ring and look for the screw. Thanks
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
carid
Apr 30, 2015 07:00 AM
mievil
Apr 28, 2015 11:02 PM
tkcne
Apr 18, 2015 02:33 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
