1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1991 honda civic sedan window problem
Old Mar 18, 2015
joee182's Avatar
joee182 is an unknown quantity at this point
Alright so I got a problem with my front driver side window. It doesn't roll all the way day and I took it to an auto glass place and the guy told me I needed to replace the window gasket. So my problem is I don't know where I can find a window gasket. Ive googled it and I cant find anything on it. I really appreciate the help. thanks.
Old Mar 18, 2015
Re: 1991 honda civic sedan window problem
I call it a "glass run channel seal".
Online parts catalog. http://www.hondaautomotiveparts.com/
Pick out your actual car, then find "front door window" in the list.
^Pic like this^
Item # 9 or 17 is the seal.
Catalog, you gotta pick left or right. Left is drivers side.
Catalog calls it CHANNEL, L. FR. DOOR RUN
Catalog also says it's discontinued for the car I looked up. (4 door LX)
So get the part number and google that. See if anyone has it.
Next choice is junkyard parts I guess.
HTH
Old Mar 18, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
See post 2 above.^^^^..forget this
Look here. Find out for sure what is binding it. I had a 94 that one of the bolts came loose that holds the glass to the lift. . If it's trim, get it out of the way and once window works, you will see what you need. Probably pull door panel first. http://www.collegehillshondaparts.co...or-window-scat
Old Mar 18, 2015
^This.^
I've seen seals come out of the tracks for unknown reasons, sometimes it can go back in ok, and sometimes it gets damaged and needs replaced.
I've seen the metal guide # 8 or 16 break off the anchor tab and cause problems
I've seen the same guides on either end damaged (bent) from accidents
I've seen a ton that just need a liberal dousing of spray silicone lubricant to get the glass to move easier. Years of dirt accumulated in the seal causes the glass to drag.
Old May 14, 2015
joee182's Avatar
Thanks for the reply guys! Sorry to come back so late after.
But I saw my thread and thought I'd continue on here instead of starting a new thread.
But I'm trying to figure out what the name of this part is, all that comes up is the plastic on the lower part of the window.
I'm not sure why it came out sideways, sorry. But the part I'm talking about is starting to peel.
Old May 14, 2015
The one on the outside, the horizontal moulding with half the black missing?
I think you want # 7/9, 9 is for the left front
Linky: http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry 2=1991&catcgry3=4DR+LX&catcgry4=KA4AT&catcgry5=SID E+PROTECTOR
NOTE: DX has a different part number from EX and LX so start at the beginning (www.hondaautomotiveparts.com) and look up your own car.
EDIT: Catalog says this one I looked up is discontinued. Good luck searching.
Old May 14, 2015
joee182's Avatar
The part I'm looking for I believe might be #8. It's a rubber seal. The part with half black half white is part of the door I believe. But thanks! I'll look for it on the site
vtec92
May 4, 2017 03:20 AM
Rinzlor
Apr 24, 2015 10:33 AM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
aus10
Apr 13, 2015 09:26 PM
