8th Gen 2006 - 2011.
Governing
Old Mar 4, 2015
jpilot17's Avatar
jpilot17 is an unknown quantity at this point
Governing
I've been having this intermittent problem with my 07 civic. Occasionally the engine light come on and when it does, cruise control doesn't work and the engine governs at 3500rpm. I brought it into the shop before it became intermittent and they said it was an oil pressure sensor and changed it but due to the fact that it is intermittent, I haven't brought it back in haha.
Thanks!!
Old Mar 4, 2015
Re: Governing
What's the fault code? (The actual code number, not your description.)
Checked and filled oil level? Is/was it low?
Old Mar 4, 2015
jpilot17's Avatar
Re: Governing
Oil is good. I've had a few routine oil changes. I don't have a code reader so I'm not sure what it is. But sometomes, I'll turn the car on and it will run perfect - no check engine light, cruise control working etc.
Old Mar 4, 2015
Re: Governing
Cruise is disabled when there's certain fault codes, that's normal.
Report back with more info when you can get the codes read?
Stock 99
Sep 5, 2015 06:06 AM
Unstoppable
Sep 6, 2002 08:06 PM
