2nd gear slipping out when I'm making a turn
Old Feb 19, 2015
RafBys629's Avatar
RafBys629 is an unknown quantity at this point
As the title says, whenever I'm driving and about to make a turn (sometimes just going from 1st to 2nd) my 2nd gear slips which causes the car to grind the gear (one of the most horrible sounds I have ever heard). I changed the clutch fluid to see if this would help, which it did only slightly. Would a MTF drain and fill possibly fix this issue. I don't have the money for a transmission swap or rebuild.
Thank you in advance.
Old Feb 19, 2015
Re: 2nd gear slipping out when I'm making a turn
2nd gear synchro. I'm pretty sure all of us with 01-05 MT civics get that problem. I read that using Pennzoil synchromesh helps the problem, so I tried it, only to discover it serves as a bandaid on an open wound.
Old Feb 20, 2015
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
Yes that is a likely culprit, but any gear grinding\popping out issues the first thing to eye is all the motor mounts. Remember KISS keep it simple stupid (acronym, not accussitory).
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
chuffsy
May 15, 2015 12:50 PM
Russps
Nov 8, 2001 02:00 AM
