Help me diagnose this sound!
Old Feb 18, 2015
trellex's Avatar
trellex is an unknown quantity at this point
First time post! This place has tonnes of information, but I can't seem to find anything that sounds like this terrible rattling:
https://vimeo.com/119706824
Now, this sound used to be alot quieter, but up until this last week, it's been getting worse and worse. Symptoms include:
1) it's very noticeable on idle now, but as soon as it rev's past ~2000 rpms, the noise disappears.
2) The sound definitely comes from the internal of the engine.
3) After running for about 15 or so minutes, the sound lessens a lot, but doesn't go away. About a week or so ago, it did quieten down enough that I couldn't hear it.
Any suggestions as to what it could be, would really help me out!
Thanks!
Old Feb 18, 2015
mikey1's Avatar
Re: Help me diagnose this sound!
holy crap.....not good whatever it is,
possibilities are endless, pop the valve cover, if your lucky it will be something in the valve train and not in the bottom end, stiff, stuck, or broken valve/spring? damaged valve thats not fully closing?
good luck!
Old Feb 19, 2015
trellex's Avatar
Awesome, I'll make sure to do that. Are there any links out there on how to pop that open?
Old Feb 19, 2015
Almost sounds like when I developed some rod knock. Pull the vtec solenoid and look at the screen. Mine was almost completely clogged eith metal flakes.
Old Feb 19, 2015
trellex's Avatar
Do you have any diagrams, tutorials or videos of where I could find the solenoid?
Old Feb 20, 2015
The VTEC solenoid is #9 on the drawing. Well, the assembly encircled by #9. The screen I speak of is #10, which is a rubber gasket/o-ring with the screen in the middle of the 3 ellipses. It's attached by 3 bolts accessible from the rear of the engine. May be kind of hard to get to, but other than access to the bolts, it's rather easy to remove.
actual view of the VTEC solenoid, courtesy of ezone
https://www.civicforums.com/forums/1...ml#post4649242
Old Feb 21, 2015
trellex's Avatar
Thanks! I'll look into this over the next few days! I think it might be a bit easier for me to get at as I have CAI, but either way, should be fun.
If that is the case, there being metal flakes in the catch, what should I do after that?
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
frisbeeguy2
Jul 30, 2015 03:00 PM
Brandon Vlasak
Jul 25, 2015 07:25 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
1khilari
Jul 9, 2015 08:12 PM
