Transmission will not go into gear
Old Feb 17, 2015
Loftonx5's Avatar
Loftonx5 is an unknown quantity at this point
The AT will not go into gear unless I reset the PCM (either by battery disconnect/fuse removal-reinsert-or OBD scanner tool).
Once I reset the PCM is will go into gear, drive for a bit and then it needs to be reset again. when I say a bit it could be 500 feet or 1/4 mile. Any recommendations? There are no error codes.
Old Feb 17, 2015
Poopies's Avatar
Super Moderator
Re: Transmission will not go into gear
Does it upshift when you drive it for a bit?
Old Feb 17, 2015
Loftonx5's Avatar
Yes, once it is reset it will shift through all gears. However, as it heats up the time of failure shortens. If it is cold/cool, all conditions seem normal.
Update: No codes register when it fails. Unplugged speed sensor, got P720 error, so I guess PCM works.
Tested car on jackstands. Right wheel turns but left does not.
Tried to get it moving but is would not continue to turn (1 spin = 1 turn, no momentum)
Tested solenoids Ohms/operation satisfactory
-Shift solenoid A&B OK
-linear solenoid OK
- Lock up Solenoid A&B OK
screens clear
Dani1993
Jul 24, 2015 09:02 AM
Bounddyy
19
Jul 20, 2015 02:42 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
Jul 12, 2015 11:54 AM
