Will this work?
Old Feb 15, 2015
Greenmonster's Avatar
Greenmonster is an unknown quantity at this point
Will this work?
So my situation is that I have a CA emission vehicle and replacing the cat cost more than the car itself. I just moved and need to get it registered, I called the dealership for a replacement they wanted 1500 dollars for it. After researching I found this
http://www.carid.com/2001-honda-civi...FdcRgQodxGoATQ
I need to know if this will work, its EPA certified and 50 state legal, to turn my CE light off.
Thanks Everyone
Old Feb 15, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: Will this work?
If it's model 82681 then it should be. It's C.A.R.B certified so it should work for CA.
Assuming that your CEL is on for the cat not working properly.
I ordered the same one for my car. I think I actually found it cheapest on amazon. Maybe rockauto. Can't remember. But I want to say it was closer to $350. If you order an OEM replacement from http://www.hondaautomotiveparts.com/ it's about $700.
Old Feb 15, 2015
Re: Will this work?
Hey where did you get yours installed?
Old Feb 15, 2015
Re: Will this work?
Bolt on, DIY?
Old Feb 15, 2015
drhawkinz's Avatar
Re: Will this work?
yeah it's pretty simple
https://www.civicforums.com/forums/1...ml#post4675191
Old Feb 16, 2015
Re: Will this work?
2 spring-loaded bolts from the exhaust manifold to downpipe flared flange, 3 bolts on the downpipe to b-pipe flange. Doughnut gasket on the former, possibly a graphite impregnated gasket for the latter. Easy swap. The biggest pain in the *** part is getting a wrench on the top bolt on the downpipe to b-pipe flange, but with enough patience, it's doable.
Old Feb 16, 2015
Re: Will this work?
I could definitely do this myself, and I have on my pathfinder. However I live in an apartment complex that bans working on cars in the parking spaces. Any where you would suggest getting this done at? I have tried midas but I feel like the dick me around too much.
Old Feb 16, 2015
drhawkinz's Avatar
Re: Will this work?
I think it'd be easy enough to hide from the apartment complex unless you live across from the office. As long as you're not doing an engine swap I'm sure they'll be fine. Might just yell at you a bit or something.
If not then work on it at the back of a lowes or autozone parking lot so if you need something you don't have to go far to get it.
Old Feb 16, 2015
Re: Will this work?
Do it in an autozone parking lot.. lol
Old Feb 16, 2015
Re: Will this work?
Thats actually not a bad idea in could even borrow tools from them too haha
Old Feb 16, 2015
Re: Will this work?
Google search for "Do it in an autozone parking lot" returned this
and this
and this
LOL
Yea, I'm bored
Old Feb 16, 2015
drhawkinz's Avatar
Re: Will this work?
i'm impressed that the fire was out in about 45-60 seconds after they hit it with the hose.
why the hell didn't the store employee use the fire extinguisher that's usually at the front door???
Old Mar 2, 2015
Re: Will this work?
Just to update you all, it did work.
werdnahall
May 17, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
intensity
May 12, 2015 10:43 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
