Car Boggs and sputters and turns off
Old Jan 18, 2015
Peusdeus's Avatar
Peusdeus is an unknown quantity at this point
1999 Honda civic si. 42k miles. Yes very low miles. Cars turns on and idles fine. Drives good for about 3 to 5 miles under normal and heavy throttle. After a while it's starts to bogg and sputter in fourth and fifth gear. In neutral and in gear the car will shut off. No check engine light! I get a strong suffer smell from the exhaust. 30 seconds later the car cranks for a little and turns on. Drives normal and a little while repeats problems. I've changed the following parts. New cap, rotor, plugs, wires, ignition coil, ignition module and catalytic converter. Started up perfect. Ripped through 1st, 2nd, 3rd gears without any hesitation. Ran like a beast. Couple of more miles it bogged out and died. Still no check engine light. Please help me! Thank you. Oh and one more part I'll change when it comes in. Ignition relay.
Old Jan 18, 2015
Peusdeus's Avatar
Re: Car Boggs and sputters and turns off
Sulfer* not suffer
Old Jan 18, 2015
Sulfur = Pig rich
Got a scanner? Scangauge? Live engine data readout?
What's the coolant temp read in the datalist when it acts up?
What's the primary O2 sensor reading when it acts up?
What are the Short term and Long term fuel trims doing when it acts up?
Unplug the primary (front) O2 sensor and drive it a day or two. See if this problem is gone while it's unplugged.
Old Jan 19, 2015
Peusdeus's Avatar
Originally Posted by ezone
Sulfur = Pig rich
I don't have a scanner, wouldn't it throw a check engine light cause of a faulty read o2? I don't have readings.....
Old Jan 19, 2015
NO!
It would only turn on the light if it failed in a way the computer can detect.
mikemc422
Aug 9, 2018 05:41 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
McD
Apr 22, 2015 05:28 PM
GH04si
Apr 15, 2015 08:13 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
