8th Gen 2006 - 2011.
Mice Chewed Wires on engine
Old Jan 16, 2015
deafinition's Avatar
deafinition is an unknown quantity at this point
I woke up to discover that my 2010 Honda Civic Si will not run above 3000 RPM's. After looking under my hood I found some wires chewed through on the engine. There is a navy blue plastic connection with 3 wires chewed flush. Those wire are supposed to be connected to the other set of wires that have copper fraying exposed right above it. My check engine light is on as well as my VSA light on the dash. Does anyone know what this part of the engine is? Any ideas on how much this will cost?
Old Jan 16, 2015
CraigW's Avatar
Re: Mice Chewed Wires on engine
Do you have any soldering skills or equipment ??
May just involve connecting loose wires back to 3 pin connector.
Old Jan 16, 2015
I do, but I wouldn't feel comfortable doing that kind of work on a car engine.
Old Jan 16, 2015
CraigW's Avatar
Can you get any idea of wire colors where they are cut close at the 3 pin plug ???
....if not you may need to get that info from another owner, or another 8th gen Si.
If those match your loose wires.... and you CAN still make a connection at the plug it would be pretty easy fix.
Old Jan 16, 2015
I can take a closer look when I get off work. I also took this in to Pep Boys and they pulled this code up.
Old Jan 16, 2015
Easy and cheap is to patch the damaged wiring. I do this all the time, we have plenty of rodent problems in my area. It can be tedious and requires a bit of skill, but very doable and reliable when done by someone with experience and care.
It also helps to have a selection of scrapped/used wire harnesses to scavenge terminals and connectors from.
The only way to repair using what's offered in the factory parts catalog is to replace the entire engine wiring harness, and that ain't easy or cheap.
Next trick will be to stop the rodents from enjoying your engine compartment.
Old Jan 16, 2015
CraigW's Avatar
Not a mechanic but... that is likely the sensor that the blue connector is attached too.
MAP/Baro.
Old Jan 16, 2015
MAP/Baro.
It is the MAP sensor.
Old Jan 16, 2015
Is this something that I should let a dealer take care of or can I order the part and put it in myself?
Old Jan 16, 2015
One more question. Is the map sensor just the plastic piece attached to the engine? Will it come with wires or will I have to get a wire assembly harness?
Old Jan 16, 2015
CraigW's Avatar
The sensor will only have the pins, and provisions for the blue connector to attach too.
As mentioned the harness is only available as the COMPLETE engine harness.
Your best bet will be work with what you have.
Old Jan 16, 2015
You don't need the MAP sensor itself, it's fine.
You need to fix the wire harness.
Remove the chewed connector from the sensor and check it out.
Old Jan 16, 2015
I appreciate all of the help and inputs. Thank you.
Old Jan 16, 2015
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
ezone comment: Next trick will be to stop the rodents from enjoying your engine compartment.
Put mouse poison around where your car is parked / stored. These b tard rodents can rake havoc. I had them eat the speakers out of a boat I owned. Place a small container of water for them. When they eat the poison they get thirsty and look for water, the poison makes it boil in them .
Old Jan 17, 2015
CraigW's Avatar
....and hope they don't die in your car or house.
A friend used moth ***** placed around floor underneath his vintage VW.
Old Jan 17, 2015
Some time ago my GF came over and said her car was running bad and the CEL was flashing..... Raised the hood and saw critters had eaten 2 of the spark plug wires off.
Some trays of D-Con went on their garage floor that day.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
nicholaai
Apr 27, 2015 05:54 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Dmitri
123
Oct 13, 2005 08:01 PM
slammed2k1civ
Nov 6, 2001 11:52 PM
