Turns over too long and won't re-start when after 40 mins driving
Old Jan 6, 2015
Gordonbrowne's Avatar
Gordonbrowne is an unknown quantity at this point
Hi,
I have a 57 plate Civic and over the last three months It's been taking longer to start. Yesterday after a 45 minute drive I tried to start the car again after a 15 minute break and it wouldn't start. It has started again this morning albeit very slowly.
Also sometimes the headlights flash very quickly when I'm trying to start the car.
Is this a battery issue? I'm still using the original battery.
Thanks
Old Jan 6, 2015
mikey1's Avatar
Re: Turns over too long and won't re-start when after 40 mins driving
it sounds like an electrical/wiring issue to me, most likely a grounding issue,
start by disconnecting the battery, clean the battery posts and wire terminals good with a mixture of water and baking soda, use a wire bush if you have to,
make sure everything is clean and dry before you reconnect,
inspect all main ground cables/connections, make sure they are clean, tight, and corrosion/rust free.....battery ground to frame/engine, ground from engine to frame, etc etc
Old Jan 6, 2015
Thanks I'll give it a go
Old Jan 6, 2015
CraigW's Avatar
Originally Posted by Gordonbrowne
Hi,
A What ??
Big load, turn them off before starting
How old is this battery ?? (4-5yrs is new norm)
Xuhme
21
Aug 7, 2023 03:40 PM
chrisod12
Apr 26, 2015 01:30 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
