01 EX hard starting
Old Jan 1, 2015
ssman's Avatar
ssman is an unknown quantity at this point
01 EX hard starting
Need Help!!
My 2001 occasionally fails to start when it is cold until after several attempts. I have changed the PGM-FI#1 Relay but that didn't fix it. When it fails to start I can hear the fuel pump prime up for a couple of seconds. I also do not see a flashing key symbol indicating an anti-theft problem. Should I change PGM-FI#2? Is there another Main relay that could be causing this?
Old Jan 1, 2015
ssman's Avatar
01 ex rough idle
My 2001 civic idles rough and sometime will almost stall. Off idle it seams to be running fine. All I have looked at is the spark plugs and air filter and both are good. Someone I spoke to said this is normal on these cars but I don't buy that. Anyone with ideas on this?
Old Jan 1, 2015
Re: 01 EX hard starting
(Merged your threads together.)
No it's not normal.
CEL on? Got codes?
Sticking IAC valve? Idle relearn?
Old Jan 3, 2015
ssman's Avatar
No codes,will clean IAC and do the relearn procedure.
What about the hard starting issue regarding the PGM-FI relays?
Thanks
Old Jan 3, 2015
Hard start, rough idle, and stalling are likely all related to the same cause.
A poor running engine is often hard to start for the very same reason it runs poorly.
The 2 main relays: One runs the fuel pump, the other supplies power to many of the engine controls and the PCM.
If the fuel pump runs when it should, I doubt its relay is at fault.
If the check engine light comes on when you turn on the key then I doubt the other main relay is at fault.
These would be easy enough to check with a voltmeter, just tap into any of the many circuits that are powered by the relays and watch for voltage.
CarStuff
Dec 6, 2020 12:52 PM
jbradley4809
Apr 7, 2017 04:23 AM
MamaBear2015
May 3, 2015 02:17 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
black2k1vtec
Dec 6, 2001 09:49 PM
