1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1998 civic stalled now just dies after seconds
Old Nov 24, 2014
nawed14's Avatar
nawed14 is an unknown quantity at this point
Hey I'm new to this forum and was wondering if I could get some answers. I have a 1998 civic LX experiencing some problems. I was driving down the road and the car would shut off, ABS light would come on, and all the dials would go to zero then it would come back on. Happened mostly when I pushed the accelerator. Eventually the car wouldn't come back on and I had to pull over, put it in park, and start it again. I tried to take it to the mechanic the next day but now it shuts off within second of turning it on. When I move the key to the III position without turning it on, the P and D4 light would be on then it shut off. Don't know if that has anything to do with it. From other forums I've searched it could be the distributor or main relay but I'm not sure. Help????
Old Nov 24, 2014
Re: 1998 civic stalled now just dies after seconds
Just those 2 lights, or ALL the warning lights turn off?
When it dies does the dash go dark like someone turned the key off?
Ignition switch (the electrical section) is a common problem area.
Old Nov 24, 2014
nawed14's Avatar
All the lights go off as if someone had turned the key off. If it is an ignition switch problem will it be an easy fix?
Old Nov 24, 2014
Yep. Take it to your local Honda dealer.
The switch was a recalled item.
Even if it was replaced under the recall many years ago and has gone bad again, they should still honor the recall.
McD
Apr 29, 2015 03:50 PM
McD
Apr 22, 2015 05:28 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
Hrddrvs
Apr 11, 2015 11:22 PM
