help! honda civic 2003 coupe
Old Oct 18, 2014
cicero36's Avatar
cicero36 is an unknown quantity at this point
I have a honda coupe 2003 that i just bought. It comes with a keyless entry remote,but it is not working as it should be. It only locks or unlocks the passenger side door. I need to open by key the driver side door coz the remote wont unlock it. Once unlock thats the only time i can use the remote to unlock or lock the passengers side. If i dont unlock manually the drivers side door,it wouldnt unlock or lock the pax side door.How do i fix this and what seems to be the problem?
Thanks in advance for you help.
Old Oct 18, 2014
Re: help! honda civic 2003 coupe
Does the power lock work on the drivers door?
Old Oct 24, 2014
cicero36's Avatar
No. It doesnt work on the drivers side door at all. I did open up the drivers side door panels and check if there are any lose wires but i cant see anything.
Old Oct 24, 2014
2 wires operate the power lock actuator.
Unplug the connector and stick a test light in those 2 wires and see if it lights up when you push the power lock buttons.
Stupid simple test light: #194 bulb.
Simply unbend the wires on this and stick them in the connector for the lock actuator
If it lights up when you push the power lock button, then the actuator must be bad.
miatabro
Jul 17, 2015 12:12 PM
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
