2001 civic si coupe manual transmission issues
i bought my car a couple days ago and i just started driving it. when i turn it on, the shifter will not let be change gear, it only works when the car is off. after about 20mins its fine. what could be the issue as i cant drivie the car like that.
Re: 2001 civic si coupe manual transmission issues
Refill if necessary with DOT 3 brake fluid.
IF it's real empty the system may need to be bled to restore proper operation.
Then find where it leaked out at and fix it.
I didn't have a inspection done before I bought it. How do you check the fluid. I'm going to Mr lube today to have the filters changed and fluids topped up, as well as a quick look around
mattdoc
Mar 14, 2017 12:10 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
lilbluecivic
Nov 7, 2001 06:49 PM
