8th Gen 2006 - 2011.
Slight Oil Cosumption Fixed ...!!
Old Sep 14, 2014
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
Thumbs up Slight Oil Cosumption Fixed ...!!
bought my Civic Last Year 2008 with 118.00 Canadian kms on it
shortly after changing oil using 5w20 Syntheitic oil and filter I noticed
a slight oil consumption of aproximatley 400 MiLimeteres of oil at 5.000kms so the Last oil change I used a Product from BG called there (BG 109 Compression restorer) its a mild cleaner that You add to the engine oil before changing it you run the engine at 14-1500
rpm at idle for 15-20 minutes in Your driveway and change it out and what it does is it will get in behind the piston ring grooves and clean up and free any sticking rings up or carbon off them. well I have been monitoring the oil every 2.000kms and
now its been 5.000kms as of today and its STILL AT THE FULL MARK...!!
BG 109 COMPRESSION RESTORER HAS MY THUMBS UP..!!! STUFF REALLY
DOES WORK AWESOME...!!!
THANKS BG BEST STUFF ON THE PLANET
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Ocenica
May 30, 2015 06:53 PM
jakeconnor
May 5, 2015 07:30 AM
