1999 honda dx civic misfire and won't start
Old Aug 29, 2014
El Jefe's Avatar
El Jefe is an unknown quantity at this point
Hello all,
My car started off with having weird starting problems. The idle would start out really rough and I could hear the engine misfiring. Then the idle would mellow out and the car would run normally. When the car was idling it would sound as if it would be pulsating, i'm assuming it was due to high and low rpms.
I took it to my mechanic and he installed a new distributor. The problem went away for a couple of days.
Then, the symptoms started to persist again. Now, the engine won't even start. It sounds horrible when i try to crank it you can hear it misfiring and it starts to shake.
three months earlier I did a head gasket repair job I'm thinking i may have messed things up. I torqued the head bolts to specification. I made sure the number one piston was on top dead center. I checked the timing after I put everything together and it checked out right. I didn't even touch the head, i took it to a machine shop and they checked it out.
The only thing I didn't do was replace the timing belt because it was fairly new. I didn't take it off and re-install it either I just slipped it back on after installing the head gasket.
I also installed new plugs and no dice. gapped to specification.
The car ran great for the first two months. No overheating problems.
Any help would be greatly appreciated, I don't even know where to start.
Old Aug 30, 2014
mikey1's Avatar
Re: 1999 honda dx civic misfire and won't start
what do the plugs look like?
i would start by checking the timing belt/timing, verify its correct,
next do a spark test, then compression test
Old Aug 30, 2014
Try a few more distributors?
"Also, aftermarket distributors for Hondas are junk. Yep, I said that. Can't tell you how many people have come to me with check engine lights and no-starts because they have an aftermarket distributor on their vehicle."
Old Aug 30, 2014
El Jefe's Avatar
hey thanks for the replies,
I took the plugs out, and valve cover off. The plugs had oil on the electrodes. Does this mean I just have to replace the valve oil stems?
I will do a compression and spark plug next and give you guys the results
Old Aug 30, 2014
Why aren't you back at your mechanics shop? Surely there is a warranty on his work that only kept the car going for 2 days.
Old Aug 31, 2014
El Jefe's Avatar
sorry just to clarify my mechanic doesn't have his own shop, he works out if his house.
Old Aug 31, 2014
Originally Posted by ezone
why aren't you back at your mechanics house? Surely there is a warranty on his work that only kept the car going for 2 days.
ftfy
Old Sep 9, 2014
El Jefe's Avatar
yea so I installed new spark plugs and the car fired right up, then later that day after stopping and re-starting again it still started to boggle and misfire when starting the engine.
I did a compression test cylinders 1-4 170 - 165 - 165 - 180 . However, the compression test for cylinders 1-3 were kind of slow to build up that pressure. It took about 15-12 seconds of cranking to get it up that high.
tested spark and it was good. I'm thinking worn piston rings or valve stem seals what do you guys think?
Old Sep 9, 2014
I might be wondering if it's trying to flood itself, like see (on a scanner) if the coolant temp sensor is reading inaccurately.
aultman1990
Apr 19, 2015 07:14 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
aZnVoYCe
Dec 7, 2001 12:41 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
