05 LX Cranks but will not start.....
Old Aug 29, 2014
ramstein's Avatar
ramstein is an unknown quantity at this point
3 days ago my battery died b/c headlights left on over night. I jumped it seemed to recharge nicely. Couple days later the car just would not start. It cranks pretty good, just does not start. Fuses look good. Timing belt was changed just a few months ago. No fuel leaks that I can see. Then I took a spare spark plug, put it on a coil and attached to one end of a jumper cable and the other end to the neg terminal on the battery. No spark. Is it my crankshaft position sensor? What else? Any ideas, advices will be appreciated. Thanks
Old Aug 29, 2014
mikey1's Avatar
Re: 05 LX Cranks but will not start.....
i think you need to describe this in more detail......
what EXACTLY did you do? use more then one or two sentences
Old Aug 29, 2014
ramstein's Avatar
I am not sure how else to describe it. Apparently the car does not have spark. All fuses intact, battery is fine, grounds look good. I am not sure what direction to go from here.....
Old Aug 29, 2014
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Seems similar to this post:
https://www.civicforums.com/forums/3...d-n-start.html
Have you read this post?
Old Aug 30, 2014
mikey1's Avatar
im trying to verify if you came to this conclusion properly,
all 4 coils have no spark?
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
68camerors
Sep 24, 2015 06:18 PM
Skunkone
Sep 24, 2015 04:38 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
