96 civic dx speedo problems...HELP!!!
Old Jul 24, 2014
blackiceyzfr1's Avatar
blackiceyzfr1 is an unknown quantity at this point
I have a 96 civic DX with a D16Y7 motor and 5 speed. When I got the car the speedo did not work. I have since then replaced the gage cluster with a similar one known to have been working. I just replaced the VSS and checked the fuse. Fuse is good. Still nothing. The entire gage cluster works except the speedo, even the old one worked except the speedo. I also should mention that I do have a CEL as well, and yes, it says bad VSS. So, Any ideas would be so appreciated!!! Also, does anybody know what the difference between the two different VSS's are that are available for the 5 speed? I know the mounting flange is taller by a 1/4" on one of them but what about the operation and plug? Will they both work?
Old Jul 24, 2014
Re: 96 civic dx speedo problems...HELP!!!
Got wires?
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
Lightman
Nov 10, 2001 06:44 PM
WeRkX
Nov 1, 2001 10:33 PM
