09 civic si help!
Old Jul 11, 2014
bmellott91's Avatar
bmellott91 is an unknown quantity at this point
09 civic si help!
I drove my si then shut it off then tried to start it again and it will turn over but not start fuel pump runs it gets spark coil packs r good & compression is good between 160-200 help!
Old Jul 11, 2014
Poopies's Avatar
Super Moderator
Re: 09 civic si help!
It takes fuel+air+spark to keep an engine running. Something is missing.
[QUOTE=bmellott91;4667188]I drove my si then shut it off then tried to start it again
So you just drove it normally to work or something, and it just failed to start? Do you ave any mods on it?
How is the fuel level?
How old is the battery?
How are those fuses looking?
[QUOTE=bmellott91;4667188]it will turn over but not start
If it cranks, the starter is probably ok. Does it sound weak and labored or normal?
Originally Posted by bmellott91
fuel pump runs
How can you tell? You can hear it when you have the ignition in the "ON" position?
it gets spark
How can you tell? Did you check all the spark plugs?
coil packs r good
Are they? See above.
Okay. I'll take you at your word.
help!
Coherent sentences save time. Help us help you!
Old Jul 11, 2014
Those numbers don't impress me at all.
Can you be more specific?
Got codes?
Got angry blinking green key?
Got mileage?
Got oil change history?
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
