2001 civic dx, D17A2
Old May 14, 2014
jervang's Avatar
jervang is an unknown quantity at this point
Exclamation 2001 civic dx, D17A2
looking for advice on how to diagnose/fix my car. The engine will roll over, but wont start, shakes like a bitch when its trying to start. check engine light is off.
Old May 14, 2014
mikey1's Avatar
Re: 2001 civic dx, D17A2
your going to need to provide a hell of alot more info then that
Old May 14, 2014
JM Auto Racing's Avatar
JM Auto Racing is an unknown quantity at this point
Did you test for fuel?
Did you test for spark?
Do the lights dim when you try to start the car?
Old May 14, 2014
jervang's Avatar
what do you need to know, im new to this.
Old May 14, 2014
Did you test your battery load?
Do you hear your fuel pump clicking on when you put the key to the "on" position"?
Old May 14, 2014
jervang's Avatar
how would i test the battery?
i can hear the fuel pump click when its in the on position
Old May 14, 2014
jervang's Avatar
any help would be appreciated guys
Old May 14, 2014
You can take a volt meter and make sure it's putting out around 12v.
Do your lights dims when you try to start the car?
Start with that.
Then you can pull out your fuel line and crank the car a bit to see if your getting fuel. Then you can test for spark. Pulling a spark plug is the easist way.
Old May 14, 2014
jervang's Avatar
Start with that.
tried cranking it, the battery is dead so i have it charging now, for the spark do i just pull one out and crank it or do i need to touch it to a ground?
Old May 14, 2014
Before you do that. Just charge the battery fully and then try it.
Old May 14, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
YES do not check for spark holding it in your hand. That's 30K volts at least -- and if you're really unlucky, it'll find a tenth of an amp on your body and ground through it.
Best thing is to buy a tool to do this -- looks like two clips on a cable but one fits on the plug, the other on a known good ground (best on the engine, not the neg terminal on the battery). Because the D17 has coil-on-plug theres 1) no way to hold the plug on the coil and 2) there's little to no slack with the primary wires to touch the plug to a ground.
When was the fuel filter last changed?
Check back after the spark test...
Old May 14, 2014
jervang's Avatar
the car was purchased used so god knows when it was last changed, and ive been doing some research, best ive found is the HEI ignition tester, is it good or do you know of anything better?
Old May 14, 2014
Yes that will work if you know how to use it
If not, here is a great article:
http://easyautodiagnostics.com/HEI-S...k_tester_1.php
Old May 14, 2014
Best thing is to
Get some other sucker ---I mean person-- to hold the coil and plug in their hand to check for spark.
If they hit the hood and scream and cuss at you really loud, you probably have good spark.
Old May 15, 2014
jervang's Avatar
Hi I posted yesterday about my civic not starting, the starter cranks the fuel is pumping, ive checked my coilover boots and replaced my spark plugs but the car still will not run. Any advice at all would help thank you
Old May 15, 2014
I merged your new thread with this older one.
In the meantime, I moved it from the 8th gen, yours is NOT a 8th gen, it's a 7th gen, so STOP posting in there.
Old May 15, 2014
jervang's Avatar
Sorry im new to this site I thought I was in 7th
mattdoc
Mar 14, 2017 12:10 PM
bambuski
Nov 12, 2001 10:35 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
liljoe
Nov 4, 2001 01:27 PM
