Interior Electrical Accessories Problems
Hello,
I have a 2001 Honda Civic DX sedan. It has been a great car, but since 2004 or so, it seems the electrical system is going haywire. Here are the problems I have noticed:
- Dash lights alternate between brighter and dimmer every 30 seconds to a minute.
- At the same time, if I am operating the interior fan on A/C I can actually hear the speed of the fan drop and rise. In fact, in one of it's "weaker" cycles, I can change the fan selector speed between the highest and second-highest speed, and there is no audible difference. Then 30 seconds later, I can hear a difference as I switch settings.
- If I run the A/C or rear defogger, the speed of the wipers slows down considerably.
- I have had a high rate of failure of interior dash lights, and I am sure this is rare. In the past two years, my odometer light, "A/C" backlight and "circulation" backlight have all failed, as has my dome light. I know the dome light may need replacing periodically, but I have owned many other cars with over 100K, and I have never needed to replace dash lights.
Also, I had to replace the alternator and battery simultaneously in the car twice! Once in 2009 and once in 2012. The car just would not turn over at all. I was able to get a jump from a friend, but even after I drove the car for 300 miles and shut it off, it would not start again. The alternator failed to charge the battery.
As these same symptoms are happening after two batteries and alternators, I am frustrated beyond belief!. Are there any other components in the electrical system that may have been overlooked and could be causing trouble?
Thank you all for your help,
Dan
Dan
Re: Interior Electrical Accessories Problems
I'd want to know what the system operating voltage is during the bright-dim events. Just how much does the voltage fluctuate, and how low/high does it go?
So....
Where'd your alternators come from? A parts store that is open on Sundays?
CarStuff
Dec 6, 2020 12:52 PM
werdnahall
May 17, 2015 11:37 AM
