97 Honda Civic won't start!
Old Apr 23, 2014
SchwabVang's Avatar
SchwabVang is an unknown quantity at this point
First things first I have spark (Can't remember the color) and my fuel pump is definitely pumping. (Hear humming and fuel rail puts out some strong spray. I've checked my compression and each cylinder have about 80 pressure in each one. Could this be because of a head gasket? My car just cranks for days and won't fire up. I'm leaning towards head gasket or timing belt slip! Any suggestions?
Old Apr 24, 2014
Lordsin's Avatar
Lord Sin
Lordsin is an unknown quantity at this point
Re: 97 Honda Civic won't start!
It could be because of a timing belt slip or possibly a bad crankshaft sensor.
Old Apr 24, 2014
Color of a spark is not relevant.
What's important is "How wide of an air gap can the spark jump?" If measuring at the plug wire ends, you need to have spark strong enough to jump at least 1/2 inch gap.
If I was the one that did the test, that would be absolutely lousy. I expect to see 180+ PSI on my gauge when all is well.
I can't vouch for your methods or equipment, so I can only assume the results are correct....... My guess: Jumped time, inspect the timing belt..
No IMO.
Old Apr 25, 2014
SchwabVang's Avatar
Thanks for all the input. I'm glad to hear that a timing slip may have been the issue because of everyone I talked to said the same thing. Very knowledgable information.
vtec92
May 4, 2017 03:20 AM
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
