Location of O2 sensor
Old Feb 22, 2014
scottyd540's Avatar
scottyd540 is an unknown quantity at this point
Hey there!
The check engine light came on in my '04 Honda Civic EX.
I hooked up a code reader and it came back with the P0134 O2 sensor fail on Bank 1, Sensor 1.
I did some searching on the net, and couldn't really find a clear answer as to the correct location of the Bank 1, Sensor 1 location on the '04 Civic.
I'm not sure if it's the sensor that sits near the engine block, or if it's the sensor that's near the catalytic convertor.
Anyone know where this might be? Thanks!
Old Feb 22, 2014
Re: Location of O2 sensor
#1 is ahead of the cat, in the pipes between the head and the cat. First sensor in the exhaust stream.
Sensor #2 would be in or after the cat.
Old Feb 22, 2014
out of the 8/9th gen section and in to the correct 7th gen section! Moved!
Old Feb 22, 2014
Dangit, I missed that again LOL
Old Feb 23, 2014
scottyd540's Avatar
So is that underneath the car or in the engine?
Also is that considered upstream or downstream?
Old Feb 23, 2014
Have you located all two sensors on the car yet?
Old Feb 23, 2014
crxmanpat's Avatar
Pusher Jets Rule!
crxmanpat has a spectacular aura aboutcrxmanpat has a spectacular aura about
See this diagram. Sensor 1 is Item 7, Sensor 2 is Item 8.
Old Feb 23, 2014
That's an LX setup. OP has an EX.
That means it's part #19, and the pic makes it as clear as mud.
Old Feb 24, 2014
scottyd540's Avatar
Well, I have located the one that is illustrated as item #7 in crxmanpat post.
But from your illustrated post, it looks like I'm gonna have to get under the car.
I'll hop under there and take a look and see if there is one there.
Old Feb 24, 2014
LX has the cat mounted in the exhaust manifold (first parts pic from Pat), whereas EX has the cat located further away from the engine, under the car (2nd parts pic from me).
The sensors are in different places on each version, but they are always in the same relationship to cat placement, i.e. primary or secondary, ahead of or in/behind the cat.
HTH
Old Feb 24, 2014
And FYI the front sensor is an A/F sensor, not an O2 sensor (even though it is called that). They look about the same, do the same job, but the internal workings are entirely different and cannot be substituted one for the other. The computer is not the same either.
Old Feb 24, 2014
scottyd540's Avatar
Ahhhhh, ok.
Gotcha.
So, I am looking for an EX upstream O2 sensor.
And the location is under the car for the 04 EX.
I think I get it now.
Thanks for all your help!
Old Feb 24, 2014
Ahhhhh, ok.
Gotcha.
So, I am looking for an LX upstream O2 sensor.
And the location is under the car for the 04 LX.
Erm....You sure you got it?
You said your car is an EX in the first post.
Find your cat, then locate the two sensors.
Old Apr 4, 2014
scottyd540's Avatar
DAP! Yes, I meant EX, not LX. Sorry. I edited my previous post.
Hollywoodsnake
Sep 20, 2015 12:58 PM
Balkos
Sep 11, 2015 11:39 PM
Donahue
Sep 8, 2015 09:00 AM
stl01civic
Jan 11, 2005 03:00 AM
Kamikaze
May 22, 2002 07:39 AM
