Confused about ignition wiring test results
I'm confused. Can anyone explain this?
I had no spark on my 1990 Civic. I did the coil and igniter tests in the FSM. I didn't have continuity on my white wire and blue wire (steps 5 and 6 in the Igniter Unit Input Test).
I finally just replaced both the igniter and coil, and the car started.
BUT I never found continuity in the blue or white wires.
Shouldn't the motor fail to start without continuity there?
Re: Confused about ignition wiring test results
When you say you didn't find continuity, what do you mean? The blue and white wires should each go from the igniter to some point on the chassis.
Was it a good chassis ground spot? No paint or rust. You should get continuity between both of the wires as long as there connection to the chassis is good.
If WHT had no continuity to ground on step 5, you should have never made it to step 6.
Was your meter set to the correct setting to test continuity?
(Who cares? It runs now! LOL)
The factory service manual page I posted says to "test for continuity between the WHT wire and the body ground." I set my multimeter to test for continuity. Then I put one probe on the white wire. I put the other probe on the chassis. I tried multiple spots on the chassis, even right where the g101 and g151 grounds connect at the thermostat housing. I did not have continuity.
You're right though. The freakin' thing started.
I must be misunderstanding something about how to perform that test.
Yes, I even tried it in several locations. I must have done something wrong or misunderstand the instructions because after putting in a new coil and igniter it started even when I didn't get the continuity reading. Oh well. It's a mystery.
Unless I'm missing something in the wiring diagram, the blue wire leads to the tach and the white wire leads to the ECM.
Neither should have true continuity to ground?
That would make sense since I didn't get a continuity reading. Do you think there's some sort of typo on that page of the manual. It clearly says "There should be continuity" between the blue wire and ground and between the white wire and ground.
Please, tell me I'm not crazy!
You aren't crazy, and I find errors in published info regularly.
I have no way to confirm, verify, or validate this as an error though.
I just looked at a wiring diagram that seemed to disagree with the input test specs.
RonJ over at clubcivic.com confirmed that the directions for testing the igniter wiring are wrong in the 1990 service manual. They are corrected in later years.
zaboomafoozarg
May 30, 2015 09:21 AM
tkcne
Apr 18, 2015 02:33 AM
twtron
Apr 17, 2015 12:09 AM
BREADFAN
Apr 15, 2015 08:58 AM
