83 honda civic 1500 lookin for tips
Just started getting into vehicles and got me an 83 honda civic 1500. lookin to fix it up, but so far i got new spark plugs,distributor cap n rotor, and wires on the way. what else should i look into to get my car running in tip top shape?
Problems:
slow start up (accelerator has to be depressed in order to start. not sure if thats how its manufactured)
slightly rough idle
smell of fuel while driving and gas(maybe a leak?)
Problems:
slightly rough idle
Re: 83 honda civic 1500 lookin for tips
carbureted right? It probably needs some TLC at this point. Could try just running something like Seafoam through a tank of gas and see if it improves. I believe the '83 had an inline fuel filter under the back seat...might be worth replacing as well.
Yessir it is carburetted. I took care of the fuel filter (primary and secondary) which was both in front and back of the vehicle on the driver side. I've also tried some seafoam type additives like Lucas's engine n carburettor cleaner. at this point now i wont die out but start up is still rough.
any other quick beginner repairs you suggest id gladly keep in mind :]
You could always pull your intake off and give the carburetor a good scrubbing with some carb cleaner!
Sounds like it. A 31 year old fuel line could have taken a dump on you. Or a leak
jessicakaybby
Apr 20, 2015 12:11 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
