GSR Build Part-Out!
Old Jan 5, 2014
sjp00422's Avatar
sjp00422 is an unknown quantity at this point
GSR Build Part-Out!
Technically not "Brand New," but the parts have never been used on the vehicle. A lot of them have been installed, but the car never got to the first start-up, part due to laziness (wiring), and part due to it becoming far too expensive to continue.
Please note: I am new to Civicforums, but far from new on Honda-Tech. Feel free to check out user profile on honda-tech.com (same user name).
Originally posted on Honda-Tech, hence why the name-plate in the pictures has H-T on it.
Up for sale is a whole slew of parts from a Turbo GSR build I have been working on for a few years. I have run out of funding, and it just got too much for me to finish it up. I am parting out what I have in order to rebuild the vehicle back to stock. All of the parts I have are brand new (the vehicle hasn't been started, some parts have been installed, but have been taken off before the motor even took its first breath). Most, if not all of the parts are in original packaging and I have receipts for all of them. Please PM me for more pictures and to make an offer/ask for a price. Don't be afraid to make an offer, the worst thing I can say is no, or possibly counter! As far as shipping, we can discuss that when the time comes, depending on size/location. If location is reasonable, I have no issues meeting or arranging pick-up.
Parts I have include the following:
Garrett GT35 "Reaper" turbo, custom built by Speed Trapp Consulting LLC in Michigan (Have full spec sheet, as well) (TiAL Purple Powdercoated) (Never been run, either) - $1,000
Edit: Added one more picture with username and date, leaving other pics up since they were taken before I sealed it all up and packaged it.
Spoolin' Performance Quick-4 non-AC manifold, Spoolin' 3" Downpipe with flex-pipe section, and Spoolin' Dumptube (Selling as a package due to fitment never had any exhaust run through it, beautifully welded by Phil at Spoolin'!) - $600
Spoolin' Performance 2.5" Aluminum Charge Piping for EK Civic with couplers and T-Bolt clamps $150
Greddy Profec-B Spec II Boost Controller - $300
Clutchmasters FX450 Clutch and Pressure Plate and Throw Out Bearing - $450
ACT Streetlite Flywheel - $150
Hondata s300 OBD1 P28 ECU with OBD2A Plug Heads - $600
Autozone GSR CV Axles - $80
Hondata Heat Shield Intake Manifold Gasket - $25
Brand new (Reman'd) Denso Starter - $125
Brand New RichPorter Technologies (Distributor King) distributor - $100
Gates Timing Belt (Installed One time, never run) - $75
B&R Fittings Turbo Feed Line (With Fittings and Brass distribution fitting)
Precision 750hp intercooler (31.5" L x 10 5/8" H x 3.5" D) - $300
Ebay Intermediate Shaft
Skunk2 Pro-Series Black 68mm Throttle Body
Skunk2 Pro-Series Black B-Series Intake Manifold with Throttle Bracket
NGK Blue Plug Wire Set
AEM Hi-Flo Fuel Rail with Fittings
MSD Cap and Rotor
MSD Blaster SS Coil
Walbro 255HP Fuel Pump - $60
There is more to this list as well, and I will add to it as I sort through everything, but feel free to ask if you don't see something on here. It is a full build part-out so if you can think of it, I am probably selling it off.
I still have to snap a few pictures for the last bit of items, but can get them for you upon request.
Thanks for looking!
File Type: jpg
Old Jan 11, 2014
sjp00422's Avatar
Re: GSR Build Part-Out!
Perfect parts for your winter projects!
Dave Brabant
20
Oct 6, 2015 12:44 AM
NROD315
Sep 4, 2015 09:22 PM
