Honda Civic 2004 / Radiator Fan problem
Old Nov 26, 2013
raziel22's Avatar
raziel22 is an unknown quantity at this point
Hey guys,i can't get my radiator fan to start. I have short the radiator switch and the fan works. I have change the thermoswitch for a new one. And the fan doesn't start either. When i push the A/C button no fan is starting either. Any ideas ? Thank you
Old Nov 26, 2013
Re: Honda Civic 2004 / Radiator Fan problem
Since it works if you jump the fan switch, there's your problem. Replace the fan switch
edit: so, I may have replied before I read it thoroughly enough. You may have gotten a faulty fan switch the second time around. My brain read "thermoswitch" as "thermostat"
Here's to me hoping ezone pops in with resistance specs or whatever specs necessary to test said fan switch
edit2: just some speculation, you may have some compounded problems. Have you tried to see what happens when your car gets to operating temp, or did you jump straight to the a/c-on test? If your fans turn on when the switch is activated, but not when your a/c is on, you may have another problem on your hands. That is just speculation, however.
Old Nov 26, 2013
raziel22's Avatar
Thx for the fast reply, when i push the a/c button, the button becomes green and nothing happen. When can get's it's normal temperature on idle the radiator fan don't come up either. When i short the the plastic thing, the one you connect the fan switch in it the fan starts perfectly.
Can i short it constantly by the time i find the problem ? Because it's been 2 week i take the bus. Or it is not good to do so ?
And i forget to say, my frinds came in with his computer reader, because i had a check engine light, the code was P0113 something about air intake sensor i think...i don't know if there is any link !
Old Nov 26, 2013
Wouldn't hurt to replace your IAT sensor, since you're throwing a code for it anyways. There might be a link, but I'm not too sure about that one.
here's some info about the IAT sensor in case you want to replace it
Part number: 37880-PLC-004
List price: $38.47 (You can get it at Majestic Honda for $26.93 plus shipping). Expect to pay a few bucks over the list price if you intend on buying from a dealership
Old Nov 26, 2013
It's a simple thermo-switch, ON-OFF type.
Contacts close at whatever temperature, somewhere around 200*F IIRC. Contacts open again a few degrees below that.
If I get really ambitious, I might actually look up a spec later.
If the AC doesn't even work, then don't expect for the fans to run with it either.
(It might be too cold to start the AC even if it does work)
What makes you think it actually needs to run? How hot is it?
Is there a problem; why are you expecting it to run now?
It can take for-freekin-ever to run the fans at idle.....If there is any cool breeze reaching the radiator, that might be sufficient cooling to never need to run the fan.
If it is 1*C up there right this minute and you have the car sitting outside, I seriously doubt the fans would ever need to run. Especially if you have the heater running.
On the P0113 IAT, make sure it is plugged in first (and no broken wires if you have CAI). If someone unplugged it with the key on or engine running, it will set the code. Erase codes and see if the same code returns right away. If it does, then you have a problem. If it stays erased, then go drive it and see what happens.
I can't remember ever actually seeing one of Hondas IAT sensors that was bad.
HTH
Old Nov 26, 2013
raziel22's Avatar
***After a 20 minutes ride the radiator becomes very hot and smoke is coming out of it.
Old Nov 26, 2013
Well yeah, the radiator is supposed to get hot.
That alone doesn't mean much to me, I totally expect it to be hot.
If there is smoke, then something leaked on it?
Water/steam (raining up there)?
Spilled coolant? Leak?
Does your temp gauge read way higher than normal?
Will that code reader show live engine data?
Exactly how hot is the engine getting?
Old Nov 26, 2013
raziel22's Avatar
i will try to clean up the radiator, maybe some coolant is still on it...after a 20 minutes ride i see a little bit of smoke coming out of the hood. The temprature gage i see in the car is ok, 1 bar under the middle.
Old Nov 26, 2013
raziel22's Avatar
But i read that the fan is supposed to start when the a/c is on ? i am right ?
Old Nov 26, 2013
This part sounds absolutely normal. No reason for the fan to run if it is not needed.
Only while the AC compressor is engaged.
If the AC system can't engage the compressor (for whatever reason -- good or bad), the fans are not needed.
Old Dec 2, 2013
GolNat's Avatar
Prelude Owner
I have a question but don't want to make a new thread. This thread came up when I searched for my question.
I have a radiator leak and need to buy a new one, but I don't know how to determine if I have a Toyo or Denso.
Is there a spot that it is stamped on? The cap says Denso, is it safe to say it is a Denso?
Old Dec 2, 2013
Don't they all look the same?
Aftermarket wants you to know the original brand, when the replacements they sell you are all the same?
They all sell you a radiator for an automatic. If you don't need the trans cooler, just don't use the cooler. Cap off the tubes and run with it.
Cap, no. Anyone can make those.
Look on the flat pads molded into the top tank, or look for a name molded into the top tank.
Catalog looks like DENSO was used in US and Canadian built cars.
TOYO was used in Japan built cars.
But refer to the first part of this reply about aftermarket stuff. It's super rare for anyone to actually buy a factory radiator here.
Stick with a well known brand if possible.
I have a note here on my desktop to avoid the brands Spectra, Murray, and CSF. Probably due to stupid cap and neck designs that aren't common standard or just the wrong type for the car.
Old Dec 2, 2013
GolNat's Avatar
Prelude Owner
Thanks for the response ezone.
I went to the Denso website to do a part search and it came up with the Denso or Toyo. I believe the only difference is the mounting for the fans. I will remove the top cover and see if it is written on the top.
Wasn't going to mess with an autozone or pepboys radiator, would rather just order an OE one (this one made it 177K miles). I did try majestic Honda and it listed either a Toyo or Denso but would't tell me which I had even with my VIN.
Old Dec 2, 2013
All I saw in the catalog was TOYO was only listed for Japan built cars (first VIN character J).
If your VIN starts with a number, it should have a Denso unit.
HTH
Old Dec 2, 2013
GolNat's Avatar
Prelude Owner
Your catalog is correct. I found Denso stamped on the top. Ordered new one.
Thanks.
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
prowl
Apr 18, 2015 07:50 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
