05 Honda Civic EX Steering Wheel Shimmy?
I have a 2005 Honda Civic EX and when I accelerate to about 40mph I get a shimmy in the steering wheel. When I back off on the gas the shimmy goes away and the car acts fine. Would this most likely be a problem with the inner/outer tie rods, ball joint or control arm bushings? I have jacked up the car and did the 12 and 6 o'clock push pull test and could not identify any play. I also did the 3 and 9 push pull test and although I cannot detect any play I can hear a slight clicking but cannot pin point where it is coming from.
Re: 05 Honda Civic EX Steering Wheel Shimmy?
I can't say for certain, but do keep it in mind.
7th Gen Civic DIY Enthusiast!
Have you gone under and checked your inner and outer CV boots for tears or leaks?
Switch BL4D3
23
Apr 24, 2015 06:57 PM
jessicakaybby
Apr 20, 2015 12:11 PM
