Clutch pedal loose??
Old Sep 15, 2013
Hoochrulez55's Avatar
Hoochrulez55 is an unknown quantity at this point
Hey Honda fans, Hooch here, absolutely loving my 09 5 speed civic. Racing red! Anyways, heres my question. I've had the car for a few months now. Its my first stick shift vehicle. It has 96500km on the engine roughly. I have a question about the clutch pedal. Its not as stiff as it used to be. I do understand that the pedal needs an inch or two of free play, but it seems that the pedal is easier to get to the free play. Almost seems easier to put the pedal down now. Do i need to adjust the free play? Or can i just tighten the pedal from the inside of the vehicle? As far as i know, all parts are original. I bought it from a honda house dealer locally. So if i take it in to get this work done, (whatever it may be) since i have 6 year 120,000 honda certified, it should be covered because this is part of the transmission. No slipping or whining can be heard. So i know the clutch itself is okay. Its just the pedal. Maybe an adjustment or a spring or two getting loose? Does anyone have any ideas? Ill answer any questions you have. Help me please!!! Thanks in advance, Hooch
Old Sep 15, 2013
GolNat's Avatar
Prelude Owner
Re: Clutch pedal loose??
The free play does need adjusting from time to time but not sure if it would be covered under warrenty since it is a normal wear item. It is low on clutch fluid?
It could be that you have gotten used to the clutch so it now feels softer even though it is not. I borrowed a truck with a clutch for a couple days and after driving it then going back to my civic my clutch felt like a feather compared to the trucks, which felt really stiff when I first started driving it.
Old Sep 15, 2013
This.
I suggest compare to an identical car.
Old Sep 16, 2013
Its probably cause im used to it lol. Fluid is fine.
mrohitredd
40
Sep 9, 2017 12:03 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Roman Rembacz
Jul 16, 2015 12:30 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
