coolant filled up to cylinder walls
Old Sep 6, 2013
redsox4020's Avatar
redsox4020 is an unknown quantity at this point
I removed my head on my 98 civic ex to replace my head gasket and I have never seen a open deck block and where the arrow is in the picture that valley that runs around every cylinder is filled with coolant all the way to the top of the cylinder walls is this normal? where the X is I know from other blocks that's where the coolant passages are.
Old Sep 6, 2013
Re: coolant filled up to cylinder walls
Your X points to an oil return passage.
You probably didn't drain coolant from the block prior to removing the cylinder head, that will certainly allow a lot of coolant into the cylinders.
And into the oil pan. Don't forget to change the oil!
Honda has used open deck blocks for many years.
Here's a pic of a brand new 8th gen block, still covered in grease:
Old Sep 6, 2013
redsox4020's Avatar
yes I didn't drain the coolant at all ive just haven't seen a open deck wanted to make sure coolant all around the cylinders was normal... thank for the reply
SimpleUser
Apr 24, 2021 02:54 AM
cyc
Jul 22, 2015 01:14 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Jul 12, 2015 11:54 AM
fordover
Jul 11, 2015 09:10 PM
