Civic coolant sensor?
Old Jun 21, 2013
woodly1069's Avatar
woodly1069 is an unknown quantity at this point
Hey guys I'm sure this will be a pretty dumb question for most but I was wondering about the gauge in the dash and where it gets it's signal. See here's the issue, I have a check engine light illuminated and the trouble code it gives is PO0118, which is supposed to be a coolant switch over temp. I think. Anyway the gauge reads perfectly in the middle of it's range and you can see that it's working as the car warms up from being cold, it never runs hot according to the gauge and the engine temp. when I open the hood seems fine. Now there is a switch just below where the upper radiator hose enters the engine, is this the cause for my engine light? Where is the switch located that operates the gauge?
Thanks in advance for any input!
Old Jun 23, 2013
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: Civic coolant sensor?
I think there are 2 sensors. 1 for the gauge, 1 for the computer. i don't know why they aren't tied together or why not just 1 sensor since they aren't exactly redundant.
Old Jun 23, 2013
Originally Posted by woodly1069
is this the cause for my engine light? Where is the switch located that operates the gauge? Thanks in advance for any input!
It's a sensor, not a switch. The coolant temp sensor for the computer is on the end of the head below the distributor. 2 wire sensor. The sensor for the gauge is in the same area, only it uses a single wire. Don't replace the wrong one.
Old Jun 23, 2013
woodly1069's Avatar
Thanks for the thoughts guys! I don't suppose driving it with the light on would cause any trouble would it? Seems like the car is hard to start when its hot now. Every once in a while I have to turn the thing over a bunch, almost like its out of gas, but then runs fine. Hope I didn't hurt anything...
Old Jun 23, 2013
It's hard to start because the computer has no clue what the real engine temperature is. This COULD lead to cat damage if it tries to dump in far too much fuel.
Old Jun 24, 2013
woodly1069's Avatar
Ok I replaced the sensor, fingers crossed no damage other than my pride. Thanks for the help!
Old Sep 24, 2013
Jryan's Avatar
Jryan is an unknown quantity at this point
Just wondering what year your civic is. Mine is 97 and it can't start when its too cold. Suspect the same issue. Did replacing the sensor solve the problem?
Xuhme
21
Aug 7, 2023 03:40 PM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
bsmiley
Apr 27, 2015 01:27 PM
Blaster30
Apr 22, 2015 12:21 PM
mrohitredd
Apr 15, 2015 08:13 PM
