Remove the engine by the top?
Old May 23, 2013
nicoob66's Avatar
nicoob66 is an unknown quantity at this point
Hi, I want to know if i can remove the engine by the top ?
Old May 23, 2013
Re: Remove the engine by the top?
You posted in 8th and 9th gens, that's 2006 and newer. I take these out the bottom.
WHY are you taking the engine out----cracked block? 8 years/unlimited mileage warranty coverage if title is clean.
Old May 23, 2013
nicoob66's Avatar
It's a 2006 1.8L and it's not a cracked block.
Old May 23, 2013
I don't think it will come out the top, but I have never tried it that way. I think the intake will not go past the windshield. I could be wrong too.
It's definitely designed to go out the bottom.
I recover the freon and undo the AC hoses from the compressor, remove the power steering lines from the pump, and take the engine with the serp belt still installed, and wiring harness. Complete.
I drop the subframe out complete with steering rack, then slide a movers dolly under the car, block it up steady and unbolt the mounts. Drop the engine and trans together as a unit. Raise car up off the dolly.
Roll them to a work area and do whatever.
2 hours max without breaking a sweat, including a few cups of coffee.
No idea how a driveway job would go, sorry.
CarStuff
Dec 6, 2020 12:52 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Grey
16
Jan 27, 2002 11:34 PM
