misfire on two cylinders
Old May 6, 2013
wade623's Avatar
wade623 is an unknown quantity at this point
im getting three codes p300 p301 and p302 it started doing this before i changed the head gasket i thought it was just from it leaking but it is still doing it i got new sparkplugs in it and i really dont know why it is doing this and when i drive it the CEL blinks and it doesnt run very good i checked if it was getting spark and it is so does anybody have any ideas on what it could be
i swear this car makes me want to
Old May 6, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: misfire on two cylinders
http://www.obd-codes.com/p0302
http://www.obd-codes.com/p0301
http://www.obd-codes.com/p0300
Random misfires usually point to a faulty Crankshaft/Camshaft position sensor, but these misfires constantly occur on Cylinder 1 & 2 it points to the ignition coils for those cylinders.
Old May 6, 2013
wade623's Avatar
i suppose maybe i could switch them around and see if the problem moves but what else could it be if it isnt them
Old May 8, 2013
wade623's Avatar
i switched them around no real difference that i could tell so i ordered a new crank sensor so ill start with that and see if it helps
Old May 8, 2013
Erase codes.
Disable (unplug) the EGR valve (assuming it is so equipped). Drive it and see if the misfire codes come back while the valve is unplugged.
It will turn on the light and set a code for the EGR, but right now I only want to see if the misfire codes come back.
Old May 8, 2013
wade623's Avatar
Originally Posted by ezone
Erase codes.
no egr only 01-05 ex and all 04-05 civics had them
also i checked the codes again today and p304 came up too
Old May 8, 2013
fsckewe's Avatar
fsckewe is an unknown quantity at this point
And someone would know what year and trim you have how?
Are the coils still swapped when p304 comes up or did you put them back?
Old May 8, 2013
wade623's Avatar
01 dx
no one told me i looked it up. and i was just saying
i put them back the way they were
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
