misfire on two cylinders
im getting three codes p300 p301 and p302 it started doing this before i changed the head gasket i thought it was just from it leaking but it is still doing it i got new sparkplugs in it and i really dont know why it is doing this and when i drive it the CEL blinks and it doesnt run very good i checked if it was getting spark and it is so does anybody have any ideas on what it could be
i swear this car makes me want to
Re: misfire on two cylinders
http://www.obd-codes.com/p0302
http://www.obd-codes.com/p0301
http://www.obd-codes.com/p0300
Random misfires usually point to a faulty Crankshaft/Camshaft position sensor, but these misfires constantly occur on Cylinder 1 & 2 it points to the ignition coils for those cylinders.
Erase codes.
Disable (unplug) the EGR valve (assuming it is so equipped). Drive it and see if the misfire codes come back while the valve is unplugged.
It will turn on the light and set a code for the EGR, but right now I only want to see if the misfire codes come back.
also i checked the codes again today and p304 came up too
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Bruce2
Sep 27, 2015 08:45 PM
