gear issue
Old Apr 30, 2013
choferazo's Avatar
choferazo is an unknown quantity at this point
gear issue
I have a Civic 04 Dx coupe and since days ago i experienced a check engine that resulted after ran out the code on oxygen sensor, after replaced- it was hard since i had poor access to tight and make sure bank 2 sensor, i was able to clear sign off, but since that episode my shift it was kinda rough at acceleration and right after been break down almost complete, i experienced little jump down on my motor. I was told to check out and replace my motor/ transmission mounts, which i did and only the front one it was broken/ replaced, also i had check out my transmission solenoids banks and they look clean, also my trans oil looks clean, not burn or contaminated much..at this point what can i try to resolve that issue?
Old May 6, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: gear issue
Try resetting the ecu and see if that helps
https://www.civicforums.com/forums/1...-pcm-idle.html
jackshepardjr
May 24, 2015 09:53 PM
cruisers10
May 12, 2015 10:46 PM
markp94
Apr 30, 2015 09:19 PM
tylerginevan
Apr 27, 2015 12:29 PM
EC3
Apr 22, 2015 07:55 PM
