1.7 Head locating pin locations
Old Mar 27, 2013
bigj-dog's Avatar
bigj-dog is an unknown quantity at this point
I'm in the process of replacing the head gasket in my cousin's '03 Civic, when I pulled the head/intake mess off, the dowel pins stuck in the head, and then abruptly fell off on the floor before I could verify which holes they went in. I am pretty sure the one on the right is in the correct position, but I wanted to throw it out there to see if anyone knew for sure before I stuck the head back on and ended up on a wild goose chase like the guy who wrote the sticky did. I'm going to try to attach a pic.
Name:	I refuse 003.jpg
Old Mar 28, 2013
Re: 1.7 Head locating pin locations
Lay the head gasket back over it. the dowels should only fit through the head gasket in 2 holes.
I think they are in the right place, but the gasket will tell the story.
(CHECKED: Diagram shows the same. Dowels on the exhaust side of the block.)
Old Mar 29, 2013
bigj-dog's Avatar
I thought about that, but the gasket that was in there had holes big enough at all options. I did grab the new one and set that on the block, and you're right, the dowels only fit in the exhaust side. Thanks for your help!
Old Mar 29, 2013
BlueEM2's Avatar
Whachya lookin at?
Definitely right
Old Mar 31, 2013
bigj-dog's Avatar
Thanks guys, it's all back together. The only regret I have is following the Mitchell instructions putting it back together and installing the intake after the head was back on instead of putting it back as one unit. I pulled it together, and I sure wish I would've put it back together that way. Thanks again!
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
mohawkboom
67
Aug 25, 2015 12:28 AM
stryder12
Jun 30, 2015 08:33 PM
Rushfan1
May 6, 2015 01:20 PM
