Cleaning maf sensor/resetting ecu??
Old Mar 17, 2013
mattandchris's Avatar
mattandchris is an unknown quantity at this point
Does anyone reset their ECU after cleaning their MAF sensor?
thank-you........mattandchris
Old Mar 17, 2013
Re: Cleaning maf sensor/resetting ecu??
If the idiot light was on, definitely clear codes.
And clearing codes doesn't always "reset" the learned values in the computer (adaptives).
The PCM will readapt learned values as you drive, even if you don't reset.
IMO It has been really rare to need to clean these MAF sensors here.
Biggest problems I see are cheap filters with poor design gaskets, damaged gaskets, and the flunkies that put them in.
Flunkies seem to let bugs and leaves get on top of the filter and get caught in the MAF, or JizzyLubes that use the cheapest filters and the rubber gasket doesn't seal properly.
RSJ
Aug 13, 2016 01:06 PM
Martinez8o5
Jul 31, 2015 10:58 PM
spyder13
Jul 31, 2015 06:31 PM
Jul 12, 2015 11:54 AM
