dry vs wet nitrous system zex kit vs others
Old Jan 30, 2013
rbeatty's Avatar
SuperTuner
rbeatty is an unknown quantity at this point
looking into putting the spry onto my boosted 98 civic, heard many opinions about dry vs wet systems, I am looking at both, leaning towards dry system, but cant figure out which is better, I have been looking at an import dry kit from nitrousdirect.com, and also a dry zex kit with the plug and play, anybody have any insight or knowledge of whats better, nitrous direct kit with purge kit is 400 zex kit without purge is 480 HELP
Old Feb 1, 2013
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: dry vs wet nitrous system zex kit vs others
I hope you don't blow the welds on the intake or fry your piston rings
Old Feb 1, 2013
GolNat's Avatar
Prelude Owner
A wet system is safer because it will ensure that you have the proper amount of fuel so that you don't run lean. A dry system sprays the nitrous into the throttle body and mixes with the fuel that comes from the injectors. If you are using a small hp shot the computer "should" be able to compensate. With a wet system the proper ratio of fuel and nitrous will mix every time causing the correct air/fuel ratio.
Old Feb 1, 2013
rbeatty's Avatar
SuperTuner
Thanks, i have a bare block im building, using motor now to toy with nitrous, thank u for the insight
cukaracha
30
Jul 26, 2015 12:01 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
CivicsClass101
Jul 9, 2015 11:14 AM
hayden55
Jul 8, 2015 11:38 PM
ZILLA
Jul 5, 2015 05:24 PM
