Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
Vibration while braking at highway speeds
Old Jan 9, 2013
wrobat's Avatar
wrobat is an unknown quantity at this point
This maybe be rather obvious but I just want to make sure my thinking is correct before I waste my time and money fixing something that doesn't need to be fixed.
I have an '06 civic lx, front rotor brakes and rear drum brakes. With about 110,000 miles on it.
Several months ago I was getting a vibration while braking, I had gotten the car about a year before hand and it had new brake pads all the way around. Being that the pads had more than half it's life still in them I just changed out the rotors, took it for a quick drive and found that the vibration was gone. My wife drove the car for a few months then when I drove it I noticed the vibration was back, she said," it never went away." But I know it did because I tested it.
Current state of the car is: Vibration while braking at 40+ in the brake pedal and slight movement/vibration in the sterring wheel.
I want to say that its the rotors but I had just replaced them only a few months ago.
Could the warped rotor warp the pads and when I replaced the rotor did something to the new rotor?
I was looking in the maitnance manual and it said it could be a wheel bearing but is only showed how to replace the rear, is there no front or did I not see it?
Thanks for all your help.
Old Jan 9, 2013
Re: Vibration while braking at highway speeds
Thoughts....
Installation errors:
Cheapo "white box" made in China rotors
Improperly tightened lugnuts
Rust buildup between the rotor and its hub (on the face of the hub).
Low quality pads that don't dissipate heat properly
Overheating the brakes:
Mountainous driving using improper downhill techniques
Expressway speed too frequent stops
Ol' lady is a race car driver and overheating the brakes
Also, see overloading of the car.
("Blued" rotors are usually easily seen.)
Storage and moisture:
"Lot Rot", a rust outline in the shape of the brake pad(s) that results from rusting of the rotors, usually happens when the car sits for a long period, but also can happen in just a day if conditions are right (or wrong, whatever). Rain, washing the car, dew, and just plain humidity can do it.
Investigate carefully.
Old Jan 9, 2013
Also, the car manufacturers recommend using an On-Car brake lathe to resurface rotors. Eliminates many variables.
Old Jan 9, 2013
STIKILLA's Avatar
STIKILLA is an unknown quantity at this point
My Reccomendation, seeing as i see problems like this everyday.
don't cheap out go for good pads and rotors and replace both at the same time. or if you really really must get the rotors machined. but in your case for the time being i would stick it with option one and replace pads and rotors on the front and i guaranteee the vibration will be gone as long as you do them right.
conspiracy90
Jun 7, 2023 01:01 PM
jbradley4809
Apr 7, 2017 04:23 AM
lilrob1213
37
Jun 29, 2015 06:45 PM
mrohitredd
May 28, 2015 10:03 AM
jakeconnor
May 5, 2015 07:30 AM
