Alternator/battery issue? Help. 2001 Honda civic ex coupe
Old Dec 10, 2012
Lt2368's Avatar
Lt2368 is an unknown quantity at this point
The battery light on my dashboard came on the other day before work. When I accelerated, the battery light turned off. When I used my brake, the light came back on the dashboard. When I was driving home from work, all electricity shut off. Lights, dashboard everything, but the engine was still running? I tried to turn on my car today and this is what happened...
[YOUTUBE]http://youtu.be/Fl4gfPknp64[/YOUTUBE]
Gonna go get my alternator checked out but first I need to start my car. Any help?
Old Dec 10, 2012
Lt2368's Avatar
Re: Alternator/battery issue? Help. 2001 Honda civic ex coupe
Video of car trying to start
Old Dec 10, 2012
Sounds sorta like a weak battery from here.
Get someone with jumper cables and jump start it off of another car.
Or charge up and test the battery.
Old Dec 11, 2012
Lt2368's Avatar
I checked my battery the day before and it was good. I just bought it a few months ago. Ill jumpstart it and ill have it looked at.
Old Dec 11, 2012
Lt2368's Avatar
I jump started my car and it completely died in a matter of a few minutes. Abs srs battery and now my green key light is lighting up.
Old Dec 11, 2012
"Good" and "fully charged" are two different things.
A battery can be weak or dead and still be considered good once it is recharged.
Car started and ran with a jump start. That proved the battery was at least too weak to crank the starter.
Car died shortly after starting:
It sounds like your alternator is not supplying enough electricity to recharge the battery and keep the engine running.
Alternator may be bad/weak/loose belt/something-- that is keeping it from operating to full charging potential.
So the alternator needs some checking.
Battery probably will still be good after a full recharge.
HTH
Old Dec 12, 2012
speedy25's Avatar
speedy25 is an unknown quantity at this point
Newer cars have lots of electronics that HATE not having expected voltages.
Repair/replace battery/alternator before you do any damage.
-SP
LionSpratt
Jan 29, 2017 11:07 PM
Civicman92296
Apr 23, 2015 09:22 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
