ECU Replacement - please help
Old Sep 15, 2012
iteadjoseph's Avatar
iteadjoseph is an unknown quantity at this point
My 2003 civic LX needs a new ECU/PCM. The dealer is asking $1000, and I'd much rather buy a used ECU and have them install it.
The problem is, the dealer says the part number is 37820-PLM-426...
...but all of the used ECUs I'm finding are 37820-PLM-L56 or L52 or L54.
Does it make a difference what the last 3 digits are? The mechanic at the dealer says everything needs to match exactly, but I'm not sure if he's just trying to get me to buy his part. Thanks for any help you can give!
Old Sep 15, 2012
Yikes 4407's Avatar
Yikes 4407 is an unknown quantity at this point
Re: ECU Replacement - please help
Have you tried your local junk yard ,find one that has been in an accident that best matches your Honda as far as year model and same motor pull computer and try to see if # match
Old Sep 15, 2012
Yikes 4407's Avatar
Thumbs up Re: ECU Replacement - please help
Price should run no higher than 100 dollars at least that's what they'd go for here in the Miami
Old Sep 15, 2012
Used? Try
www.car-part.com
Used unit will still have to be programmed before the engine will run.
I replied to your post on an old thread here
https://www.civicforums.com/forums/3...ml#post4617208
Old Sep 15, 2012
rjones7755's Avatar
Tell that dealer to suck a nut because he's blatantly trying to rip you off. Use car-part.com like they said and find a new dealer. Dont give buisness to dishonest ****s
Old Sep 16, 2012
j_dock69's Avatar
j_dock69 will become famous soon enough
x2, car-part.com is a great website for used parts
Old Sep 16, 2012
Thanks, guys. I posted this on the other thread, but that guy at the dealer was definitely trippin'. He lied to me about the part number, and when I went to see the part from my car myself, it definitely was something I can get used off of car-part.com. I just can't believe they would straight up lie to me about the part number. Whatever happened to trying to help people?
Old Jun 29, 2017
Chogs's Avatar
Chogs is an unknown quantity at this point
Originally Posted by ezone
Used? Try
www.car-part.com
If I replace the ignition that came with the used ECU would you still need to re program?
Old Jun 29, 2017
No.
A matched set should work without programming.
HTH
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
danace99
23
Jun 28, 2015 08:49 AM
McD
Apr 22, 2015 05:28 PM
thesushiboy
Apr 12, 2015 02:54 AM
AnotherDopeStyle
Nov 1, 2001 01:58 PM
