07 Rear Suspension
07 Rear Suspension
Hey guys, so I have been reading about all the issues with the 06 and 07 civics rear suspension. I have the same issue with mine and I have gone through several sets of tires and have looking for a solution. I installed a set of camber washers on the rear and have taking it for alignment. Now as I see the results from the print out, the specs show to be with in range. The range is -2.5 to -0.5 or something like that. I assume these are the specs for this model year and are considered correct. To me that is incorrect as it is not at zero. How can I get an updated alignment spec sheet or how can I resolve the issue if the alignment shop is using the specs for that model year car? Another thing I noticed is that the camber kit doesn't give me a whole lot of adjustment. I have seen pics on here that some kits have a different set of holes to bolt on too. Mine didn't have that. Any help is appreciated.
Thanks
Thanks
juror
Suspension DIY
Jul 30, 2019 03:28 AM
, jc
