Honda D16 Turbo Parts
Old Aug 24, 2012
TheToaster's Avatar
TheToaster is an unknown quantity at this point
*** All Parts came out of a EG with a D16Z6 ***
US Shipping
No Trades
AEM GAUGES
AEM Uego Digital Wideband All Parts $150 Shipped
AEM Digital Boost Gauge with sensors and wiring $100 Shipped
AEM Digital oil Pressure Gauge with sensors and wiring $150 Shipped
EG A Pillar 3 Gauge Pod
Black
$50 Shipped
$400 Shipped for it all!!
All Complete in like New conditions
Cooling System
Go-AutoWorks Aluminum Radiator
12" Slimline Fan
Mishimoto Silicone Hoses (Lifetime Warranty)
$225 Shipped
SC50 Precision Turbo
Great for 4 Cylinders
500WHP Capable
Clean, no oil leaks, no blown seals
No shaft play at all
.60/.63
T3 Flange
$550 Shipped
Go-AutoWorks A/C Compatible Ramhorn W/ DP
T3 4-Bolt Flange
38mm WG Flange
Superior Quality
Go-Autoworks Downpipe 2.5 inch flared to 3.
Must be as a set
2 O2 Sensor Bungs and flex pipe
$1000 Shipped
Innovative 60A Polyurethane Mounts
For EG civic and DC Integra.
For B and D series with hydro transmission
Billet aluminum mounts for Street/Strip
$250 Shipped
Go-Autoworks Intercooler and Piping with Couplers
Mandrel bent piping with bead rolled ends and GReddy BOV flange.
2 inch diameter hot side, 2.5 inch cold side
The intercooler filled out the entire grill on my EG coupe.
28x8x3.5
$400 Shipped
D16Z6 Cylinder Head
Ported and Polished
New Valve Guides
New Valve Seals
Resurfaced and Valve Job
Comes with VTec Solenoid, and
Y7 Media Blasted Valve Cover with New Spark Plug Seals
Made 360 WHP at 20 PSI on SC50
$350 Shipped
Sparco Harness Bar and Genuine Takata Harness
Fits EG/EK Civic
Bar is $450 new
Comes with Hardware
$500 Shipped
D16Z6 High-flow Tuck Setup
AEM High Flow Fuel Rail
AEM Adjustable Fuel Pressure Regulator
FPR has been rebuilt with new diaphragm from AEM.
Liquid filled Fuel pressure gauge with appropriate fitting.
Earls Fittings -6AN fuel filter Delete Line with Edlebrock Fuel Filter
$225 Shipped
Precision 1000cc Injectors With Plug and Play Resistor Box
Cleaned!
Low Impedance
Will fit most Hondas and Acuras
Plugs into connector by Driver's side shock tower.
$275 Shipped
D16 T3/38mm Cast Manifold
New
$40 Shipped
D16Y8 Cam Gear
Can Be used on D16Z6
Comes with Cam Key!!
$50 Shipped
Other Parts
Comp 59300 Cam
No Abnormal Wear
$200 Shipped
ARP Headstuds Z6
Torqued Twice to 65 ft/lbs
$80 Shipped
MFactory Oil Sandwich Plate
$35 Shipped
Go-Autoworks Vacuum Manifold
$35 Shipped
P28 ECU Crome Chipped
$150 Shipped
D16Z6 Stock Harness
Uncut
No Broken Connectors
100% Working
$100 Shipped
D16Z6 Starter
(Starts)
$30 Shipped
Would like to sell parts complete in the groupings if possible.
PM me Offers guys!
Old Aug 26, 2012
sl33pyriceboi's Avatar
Re: Honda D16 Turbo Parts
Tho you don't meet the minimum post requirements I will approve this thread since you have pictures.
usajags84
15
Aug 19, 2015 03:12 AM
cloudguy
Apr 28, 2015 05:02 AM
bsmiley
Apr 27, 2015 01:27 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
