D15B lost all power!!!
Old Aug 2, 2012
miguelD15B's Avatar
miguelD15B is an unknown quantity at this point
Unhappy D15B lost all power!!!
I have a 95 civic with a D15B swap. I recently noticed an oil leak coming from the transmission so me and my mechanic quickly pulled it (other than the leak there was no problem with the tranny). After taking a look we noticed a crack allowing small amounts of oil through so we swapped it for another tranny from a friend. He was unsure if it was good. Now after putting everything back together the car has lost all power. It accelerates very slowly and if I don't shift up in 2nd it will continually increase in speed (around 90mph) without redlining. Has absolutely no power in 3rd - 5th and is really impossible to reach high rpms. Now my mechanic believes it is the clutch. It was pretty worn and we probably contaminated it with our greasy hands. (no $$$ for replacement). I don't know what to think but I believe it could be the distributor or plugs (it was jammed between engine and suspension bar for awhile before we noticed it), fuel system, or maybe the ECU needs to be reset? or maybe the tranny is just bad... Any input would be greatly appreciated.
Old Aug 2, 2012
miguelD15B's Avatar
Re: D15B lost all power!!!
Does this sound like a sort of limp mode?
Old Aug 2, 2012
miguelD15B's Avatar
fuel pump?
Old Sep 14, 2012
thesandman/mma's Avatar
over 100 one hit ko's on the block
thesandman/mma is an unknown quantity at this point
theres a vtec d15b and a 3 stage vtec d15b. one has obd1 fuel control and other has obd2. different wiring harness. also different ecu. the tranny might be from a d15b that is slightly different from urs, ie as stated in beggining. theres prolly not enough fuel getting to the injectors. p08 ecu is what u want. if you haave obd1 you will need obd2 harness. or vice versa for whichever d15b engine u gots
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
carid
Nov 7, 2015 01:46 AM
Dave1984
Jul 22, 2015 06:10 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
hayden55
Jul 8, 2015 11:38 PM
