Respond to Question ASAP Please!
Old May 3, 2002
3dStylz's Avatar
3dStylz is an unknown quantity at this point
ok I installed my coilovers and the back is bouncy as all get out and makes a noise when I hit bumps, so I called the company that makes my coilovers (They are R1 Dual spring coilovers) and they told me that I need to take off the dust cover on the shock(the metal dust cover). This doesn't sound safe to me it would be really bad for the shocks. What are your guys takes on this??
Old May 3, 2002
choonz703's Avatar
choonz703 is an unknown quantity at this point
hmm.. if i'm thinking what ur sayin.... then ur back shocks are probably blown....... cuz 3 of mine are blown.. and its pretty bouncy and i hear a metal to metal hit when i run over a bump... thats only when i'm goin fast and the bump is not so deep... but deep enough... anyway... i have skunk2 coils... but i'm sayin.. thats probly what it is
Old May 3, 2002
3dStylz's Avatar
no they arn't blown I was messing with them last night and they still work, they said the that coilover was hitting on the top of the dust cover and that is what is causing it
Old May 3, 2002
VNlilMAN's Avatar
The Standard One
did you cut some of the bumpstops? cause they recommended me to cut 1.5" of the bumpstops with my neuspeed sports(about ~1.5" drop in the back)
Old May 3, 2002
DcatStylee's Avatar
DcatStylee is an unknown quantity at this point
My back left coilover used to do that...
I just sprayed some WD40 on it, and it's fine now.
Old May 3, 2002
3dStylz's Avatar
I already took the bump stops all the way out, and about the wd40 what did it fix the bounce or the noise?
I want to solve the ride and the noise so if anyone has had this problem please help!
Old May 3, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
bumpstops removed?[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old May 3, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
i have koni's w/ h&r sports......i still have the full bumpstops....i am worried to cut them, i dont want to take ne chances w/ my koni's bottoming out
peace
Old May 3, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
mwwhonda: How do you like your suspension and how much of a drop do you have? I used to have the same setup on my old Jetta and loved it even with a 2" drop.
I just don't know how good it'll be on a Civic.
Old May 3, 2002
zappa's Avatar
zappa is an unknown quantity at this point
I'll bet your shocks are blown, I had the dual spring setup on mine w/ stock shocks, bounced like hell too and bottomed out all the time,look at the spring on the shocks while theyre onthe car ; Do they look almost fully compressed? little or no space between the coils? if so probably blown..............I'm getting Konis!
Old May 4, 2002
3dStylz's Avatar
No I called the guy I got them from he said take the dust cover off the metal part he said that is what is causeing it and I can see how it can be also so I think that is the problem.
Old May 4, 2002
sumama's Avatar
sumama is an unknown quantity at this point
I have a question, do 2001 ground control coils fit on a 2002? cuz i went to some guy and he said its different. and i was like wat the heck? its the same car!!
Old May 4, 2002
DcatStylee's Avatar
The WD40 took care of the squeaking... just spray it wherever metal touches metal on your coilover.
Old May 4, 2002
aZnVoYCe's Avatar
You get what you pay for. Sorry dood. [IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old May 4, 2002
3dStylz's Avatar
these duals work good on my friends 95 civic when he bought them for that, I think I see what the guy was talking about so I am gonna try what he said
because what it looks like is the top of the dust cover is hitting the top plate in the coilovers
Old May 4, 2002
VNlilMAN's Avatar
The Standard One
ya i've heard the ground controls on the 2k1 civic is different from the ones on the 2k2 civic. i know they changed the suspension a lil but i dont know exactly what...
Old May 5, 2002
3dStylz's Avatar
OK I found my problem and it is that the top of the spring set is compresed down enough that it is resting on top of the shock so pretty much my spring isn't doing anything and I am ridding on the Aframe of the car, but I don't want to raise the back end up anymore, anyone have any sugestions?
ayoitzjulesdx98
Jul 26, 2015 02:25 PM
igorbogu
Jul 10, 2015 09:29 PM
Trennytrent
Jul 10, 2015 09:01 PM
