97 EX Fuel/Temp Gauge Problems
Old May 27, 2012
ugadawg187's Avatar
ugadawg187 is an unknown quantity at this point
Angry 97 EX Fuel/Temp Gauge Problems
So I pulled my gauges out of the clusterand installed led's in the cluster housing. I put te gauges back in the cluster housing & screwed them back in but when i plugged the cluster up gas & temp needle went all the way up & stayed there. Temp needle will drop when switch is off but gas needle stays the same. PLEASE HELP!
Old May 28, 2012
michael3n's Avatar
michael3n is an unknown quantity at this point
Re: 97 EX Fuel/Temp Gauge Problems
There's a chance you broke it during the modification. The meter tends to stick when they break.
Example: one of the tests for whether the fuel gauge or fuel sending unit is faulty involves shorting a wire, which throws too little resistance. This high current raises the gauge to full, and if it's allowed to move too far the gauge becomes damaged and sticks on full.
Xuhme
21
Aug 7, 2023 03:40 PM
Bruce.Ringler
Jun 18, 2015 08:12 AM
brian257
Jun 4, 2015 08:17 PM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
