Which would it be?
Old May 20, 2012
HCMCVTEC's Avatar
HCMCVTEC is an unknown quantity at this point
Which would it be?
I was driving home today when my transmission stopped shifting gears, like neutral for all the gear position but when I waited a few min and restarted it, i could drive but not for long.
Could it be bad/wrong trans fluid or not using ATF
Bad solenoid or sensor or ecu/tcu
1997 honda civic ex auto tran
Old May 20, 2012
Re: Which would it be?
Is the fluid full?
Does it make an odd whine noise now?
I bet it needs a trans.
Old May 20, 2012
HCMCVTEC's Avatar
Well now I'm getting P0118 P0113 P1298 P0700 P0715, all five on from my OBD2 and I just changed the trans fluid to dex3 for on. Codes were not popin up before.
Old May 20, 2012
P0715: Mainshaft speed sensor. This code can be related to a mechanical failure or an electrical failure.
HINT: You had a mechanical failure. Trans went to neutral = shafts not moving = no speed sensor output.
This info may or may not apply to your case: http://www.justanswer.com/uploads/Ho...023457_zzz.pdf
I still bet it needs a trans.
P0700 is a generic trans fail code. See the P0715.
P0118 ECT high
P0113 IAT high
P1298 ELD fault
Erase codes and then see what comes back before doing anything else. Only deal with the codes that come back.
HTH
Old May 20, 2012
HCMCVTEC's Avatar
No codes now and a whine noise near the intake manifold.
Old May 20, 2012
Ummm....Drive it until the trans acts up (goes to neutral?) and recheck for codes.
I'm expecting a whine or squeal from the trans pump whenever the internal filter is restricted.
Old May 21, 2012
HCMCVTEC's Avatar
P0700 and P0715 codes now, could the internal filter inside the trans be restricted.
Old May 21, 2012
That's probably why it goes to neutral, then will go again after you shut it off and wait a minute. I'll assume this is what it is right now...
This is not the failure, this is a symptom.
Whatever came apart and is clogging the filter is the failure.
Debris gets sucked up while fluid is moving, until enough is sucked up to restrict the pump-lower pressure to the point that the hydraulics can't apply. Trans goes to neutral.
You shut it off and wait.
The debris drops away from the filter, straight down. Start the car, it will move again until the debris gets sucked up again.
Again: a clogged filter is an indication of a much larger problem.
The internal filter is like a screen door screen. If one clogs up, there is a major problem that did it.
Clutch material is usually what clogs a filter like this.
How fuzzy was the magnet when you changed the fluid?
I STILL bet it will get a trans.
Old May 21, 2012
HCMCVTEC's Avatar
Would you know where or have blueprints I could use to for 1997 Honda civic ex auto trans B4RA.
Old May 21, 2012
HCMCVTEC's Avatar
Nevermind I found the blueprints 356 pages of it, any tips on taking it out or apart to be aware of.
Old May 21, 2012
HCMCVTEC's Avatar
The magnet had a good amount of metal on it, nothing abnormal.
Old May 21, 2012
I use factory service info.
That said, I don't do automatic trans overhauls anymore, Honda prefers us to just replace them with reman units. The shop doesn't even have any tools to do one, Honda does not make them required tools.
Back when I did trans work on other car lines, this was one of the better suppliers
http://www.transtar1.com/
If you purchase an overhaul kit from these folks, they were always good about getting rebuild manuals and tools that you need too.
Don't forget to replace the torque converter.
HTH
Old May 21, 2012
HCMCVTEC's Avatar
Thanks for your knowledge!
http://users.telenet.be/mp3.machiene...to%20trans.pdf
For this forum to help the next person.
