Diagnose This Engine Sound (Video w/ sound Included)
Old May 11, 2012
Hoac's Avatar
Hoac is an unknown quantity at this point
Hey,
long time lurker here...
I have been having this rattling/clicking noise from the engine bay for the last months. Anyone know what it could be from experience???
http://www.youtube.com/watch?v=k6sGQ...f0syZ_t9gV3D8w
Engine noise on iddle started a month ago.. Timing belt changed last year. I remember the mechanics telling me that they used a bearing piece lying around in the garage. Sound follows the engine revolution and disapear around 3k rpm.
Thanks!
Old May 11, 2012
GolNat's Avatar
Prelude Owner
Re: Diagnose This Engine Sound (Video w/ sound Included)
Sounds like it could be a pully. Did they change the tensioner when they did the belt?
Old May 11, 2012
Hoac's Avatar
I'm pretty sure they didn't touch the tensioner,said it was still in good condition.. I have about 100k miles on the car. Should I consider nto driving the car until it's
Fixed?
Old May 11, 2012
GolNat's Avatar
Prelude Owner
If it is the tensioner pulley then it could break your timing belt which could do some damage. It's weird that it disappears around 3k though! Maybe someone has had a similiar sound.
Old May 11, 2012
Hoac's Avatar
I Suppose I do not hear the sound above 3k because de actual engine sound ''overpowers'' it. I can hear it when I shift and press clutch thought.
What do I have to look for when I remove the belt covers?
Old May 11, 2012
GolNat's Avatar
Prelude Owner
Yea the engine probably is louder...I don't know if there is anyway to tell unless it is visually wobbling. You can disconnect the power steering belt and alternator belt and see if it goes away to rule out the other pulleys. Just don't leave the alt belt off for long so you don't kill your battery.
Old May 12, 2012
scooty's Avatar
scooty is on a distinguished road
Man what the heck kind of shady *** mechanic do you go to that uses random bearing pieces lying around? The only bearing involved with a timing belt change is in the tensioner and if that was not touched, ask him where he installed this bearing that was lying around.
The sound could be ac clutch bearing or alternator or power steering. Remove both accessory belts and spin each pulley by hand to narrow it down.
Old Jul 31, 2012
Hoac's Avatar
Smile Re: Diagnose This Engine Sound (Video w/ sound Included)
Finally solved the problem. Check this youtube video for explanation: [YOUTUBE]http://www.youtube.com/watch?v=H9TDHevZgQU&[/YOUTUBE]
Turns out that the mounting bolt of the Alternator was loose...
CraigW
Aug 18, 2015 07:06 AM
15EXCoupe
Jul 30, 2015 12:59 PM
