Temp gauge accuracy?
Old Mar 20, 2012
stewartfan's Avatar
stewartfan is an unknown quantity at this point
Just out of curiosity, does the temp gauge on our cars actually fluctuate with the engine temperature or is it more of an "Idiot light" that goes to a certain point regardless of the actual temperature after a while and doesn't get higher unless the temperature gets to a critical level?
Old Mar 20, 2012
513EM1's Avatar
Naturally Aspirated
513EM1 is an unknown quantity at this point
Re: Temp gauge accuracy?
The temp gauge does fluctuate with the engine temperature, atleast it should. If your experiencing problems with it, you may need to replace your thermostat.
Old Mar 20, 2012
lazlong's Avatar
It should read cold when you start it and once it gets warm it stays rock steady at the halfway mark. Otherwise you got problems.
Old Mar 20, 2012
Stock 99's Avatar
^ agreed.
Every vehicle I've ever owned the temperature gauge was deadly accurate. I drove my truck for 15 years and the only gauge it had was a temperature gauge and I would have been screwed many times if I didn't take it seriously.
Old Mar 21, 2012
Meh, these have a little illogical logic behind the gauge operation.
"the temperature gauge doesn't operate
in a linear fashion like a fuel level gauge does."
There is a broad range of temps that are covered during normal operation, and the gauge should stay pretty steady in the center normal position for all of them. (Guess:170-220 degrees all give a gauge reading steady in the middle, almost no movement.)
This is done to keep the clueless from whining about the gauge moving:
"This logic buffers the normal action of the thermostat so your customer doesn't stress out watching the temperature gauge constantly sway up and down as the thermostat opens and closes."
Once the engine is outside of its normal temps, the gauge should move either higher or lower.
HTH
Old Mar 22, 2012
stewartfan's Avatar
Thanks for the help, it's one of those things that's good to know about a car.
Old Mar 22, 2012
the only time mine went down after reaching the warm point was driving in -15F winter in the city. when i stopped at a light it would drop back to 1/4 and sometimes back to cold if i didnt keep it in 3rd gear. above freezing it should never move altho i wish they designed the logic better to make it more useful. i would love for mine to be accurate and not just tell me when the engine needs a rebuild.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Munzy
21
Oct 7, 2015 07:48 AM
cferry7
Oct 3, 2015 04:33 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
